1 - 3 of 3 Posts
I'm trying to setup REW to output via my laptop's HDMI port, and allow me to choose which channel to send the tones to. I read a bit on how to do this, but am experiencing different results than what I have read.
I installed ASIO4ALL 2.11, then connected an HDMI cable from my laptop to my UMC-200, but cannot seem to get an output option of channels 1-8 to show up in REW preferences.
When I look in preferences, I have the choices of ASIO or Java for drivers.
  • When choosing ASIO for the driver, and ASIO4ALL v2 for the device, I get "HD Audio Output 1" and "HD Audio Output 2" for output options.
  • When choosing Java for the driver, I can select the UMC-200 as the output device, but only get "Master Volume" for the output selection
If I choose the UMC-200 device, and run a "Check Levels" choosing the Subwoofer, I do get a test signal from the sub. If I choose the "Use Main Speakers to Check/Set Levels" option, I do get a test signal from the mains. So this tells me REW is able to output to the HDMI channels, but I don't see a place when I can specify which channel to use.
I tried selecting the UMC-200 device, and then ran a "Measure", and the test signal came out of the center speaker. I assume this is CH.1 ...
So where can I select which channel to perform the Measurements?
Discussion Starter #2
I figured it out ... the ASIO control panel input/output configuration didn't have the "Video Audio" output enabled by default, and didn't have my Tascam Input enabled either (I'm using a US-122 for the mic).
After I configured the ASIO control panel correctly, I now have the expected options in REW to choose which channel to output to, as well as using the Tascam input for the mic.
Are you able to do time alignment work also? I'm wondering about latency issues using the HDMI output, but a USB card/preamp as the input?
1 - 3 of 3 Posts
