1 - 4 of 4 Posts
Stupid question, but I don't see the answer anywhere. Does the 1124 convert unbalanced inputs to balanced outputs? Can I use an RCA - XLR cable in and straight XLR out to my amp? Or do I have to use something like an Art Cleanbox or Samson S-Convert?
Thanks!
· Super Moderator
Yes. As far as I know, any pro audio component with both balanced and unbalanced inputs and outputs will convert an unbalanced input to a balanced out.
But if level is too low I will need a cleanbox, Samson S-Convert or something like a MIC2200
Nothing is needed for the BFD's input. A converter is needed only if the signal from the receiver isn’t enough to drive an outboard pro audio amp to its maximum output.
1 - 4 of 4 Posts
