Hi i'm sorry if this is a stupid question but can i hook up my sub to the receiver with a regular rca cable? Or do i need a special cable?
If you're going a longer distance, a slightly beefier cable wouldnt be a bad idea. Monoprice sells good, affordable cables. On Amazon, or direct from their site.
Sturdy is always good but larger ("beefier") ain't necessary for voltage transfer if the impedances are suitable.
The skinny kind that come free (or used to) with some components probably will perform ok < 6'. But over 20'? Um.... Go monoprice.
