1 - 4 of 4 Posts
Hi,
I just bought an RX-3030 and I've connected HDMI cords to cable box (AV-1), DVD player (AV-2), and XBOX 360 (AV-3). I have connected the HDMI (out1) to my Samsung HDTV that's about 4 years old.
The cable box and DVD player are working perfectly but I'm having a problem with the XBOX:
1.] Whenever I switch to AV-3, the screen says "mode not supported". I appreciate any help given. I assume that I could connect using coaxial cables but I would rather use HDMI if at all possible.
The TV is a Samsung HL61A750A1F and is about 4 years old.
The first thing to try is switching the cables. If no change, hook up one of the other sources to the AV-3 input. Process of elimination.
Also, the X-box menu has setting for output resolution (set to 1080p).
Thanks for the input. Tried all that you suggested and also went with a straight connection to the TV but same result. I did get the resolution set at 1080p on the XBOX but still comes up as "mode not supported".
1 - 4 of 4 Posts
