I have a 5.1 surround setup (including speakers and an AVR).
For video, I use a projector instead of a TV. I also have chromecast connected to the projector (via it's only HDMI port). To route the sound from the projector to the AVR I use 3.5mm cable as output - connected via an adapter (3.5mm female to RCA) to one of the the AVR's L/R RCA inputs. I get sound, but only stereo sound, not 5.1 surround sound. The receiver I have is Marantz NR1506. Shouldn't the receiver be able to transform the 3.5mm input to 5.1 output? Or is the problem in the projector out?
I read on some forums online that one could buy a HDMI audio splitter and then send the sound from that to the receiver. Is this the only solution? and if so, could I still use the same 3.5mm/RCA connection between the splitter out and my receiver in? (The projector is far away from the AVR, I have a long 3.5mm cable, and would really want to avoid purchasing more long and expensive cables, or chaining many short ones...).
many thanks!
many thanks!
