Samsung SP43W6HF has a convergence problem. In the manual convergence (service) section, Green was showing a double image in the horizontal plane in some parts of the grid. Found bad resistors on the convergence board -replaced. Auto-convergence not effective, so I had a good play with the manual convergence. By doing a massive horizontal adjustment to green I could almost get the double image to go away. TV ran for about a half-hour, then let out a good squeal and shut down - oops. Burnt a pair of 3.9 ohm resistors on the green channel that I had replaced, so I replaced again. TV still squeals and shuts down after startup, but not with the convergence board unplugged. Supply to the CG board is 28.6V on one rail and 30.2V on the other - does that seem OK or do should they be exactly the same?
Ordered some new CG amps (STK392-040) and removed the original amps. With the amps removed, the TV will run with the CG board connected, but I don't just want to chuck the new amps in and fire up. Assuming that way too much offset to the green horizontal caused the shutdown, I checked the DC offset on all channels. Adjusted them to as near to zero as I could get, but could not get red horizontal closer to zero than 320mV, and blue horizontal no closer than -260mV. Does this explain the problem with the green horizontal double image? Have I broken something in the convergence generator?
Any help appreciated, thanks.
