Hi all, I have a 57H83 set with what I believe is a convergence problem, but I have been unable to resolve it over the past few weeks. I'll start with a description of how this all came to be, followed by the steps I have taken to try and resolve the issue. Thanks in advance for the help and support.
I'll try to give as much information as possible, so I apologize for the length
Background:
The tv resides in my basement/home theater and I don't get to use it that often, but recently wanted to recalibrate the set and get it back to it's best condition possible. In this process, I opened the set, cleaned the optics completely by removing the lenses. I also fixed a focus error on my blue lens and lined the cabinet with black felt. After I got the set back together, I began working on getting the set's settings adjusted and worked further on my service level convergence. After I got the convergence done I took it for a test run with a scene from Avatar and was completely blown away by the difference the cleaning made.
The trouble:
The set was running smoothly, when I heard a crack sound, which I thought came through my speakers, about a minute later the crack sound happened again, the screen went dark, then came back on and looked like someone kicked it right in the middle and the convergence was obliterated. I turned the set off and panicked, but then started to research the issue when I found various sites leading me towards a convergence repair. I'm a diy guy at heart but was worried that this might be out of my league.
It's clear to me that in some form or another, I caused some sort of short or malfunction in my jostling the set or in my process of cleaning, adjusting etc. but that's not really relevant
Repair steps:
I ordered a set of convergence ICs from a company that specializes in repair kits (this was prior to my thorough reading and finding the recommended supplier listing). I got the board out, replaced the ICs, looked for burned resistors and fuses (which I found none) and no such luck. Very disappointed, but I remain persistent in my efforts to want to get this fixed.
Since then, I removed the convergence ICs completely, to test the tv without them, then tried every combination of the old/new chips to see if maybe I had a failed chip from the new batch (I couldn't seem to find anywhere that said they failed in pairs, so I am assuming one may still be good but if you are replacing them, it certainly makes sense to replace both). Still no such luck in my repair.
I checked all the resistors, fuses and such that I could find related to the convergence board and looked over the board repeatedly for cracked solder points, etc.
I am pretty sure that I have missed something along the way but I am at a loss as to what that may be. I only removed the circuit board with the convergence ICs in it and not the power supply or signal boards. As such, I did not check for any blown fuses or resistors in either of those places.
Is it possible for a resistor to blow without any visual change? If so, how can I test that? What else am I missing? I don't mind ordering another set of ICs, but don't want to waste more money if I can't isolate the issue. I am toying with the idea of getting professional repair or upgrading the set, but would prefer to try and fix it myself
Here is a link to an image of what the picture looks like
http://imageshack.us/photo/my-images/259/20120119143404351.jpg/
