This should be simple as hell, but the internet appears to be brain-dead on this topic. Every search result returns options that are slow and do too much and don't provide the SIMPLEST conversion (no changes to the original other than making a copy compatible with MP4. Doesn't have to be special LG video format or anything, just a normal MP4 file that has the same audio format as the original.
I have MKV files that play properly except on an LG TV that only wants to see MP4. There are 2 kinds of MKV files: 1080p video in 24, 30, or 60 fps with h264 AND 2160p video in h265 with 24, 30, or 60 fps. These are all normal "consumer video" recorded to network hard disks. Black levels are at 16/64 and white level at 235/940. I don't want to change the frame rate or grayscale steps when the files are converted. I don't want to upconvert or downconvert anything during the conversion.
The audio of the MKV files can be PCM stereo, Dolby Stereo, and any common consumer home theater audio format from 2.0 to 11.2 so some are Atmos/TrueHD or DTS-HD/DTS:X, others are normal 5.1 or 7.1 soundtracks. I don't want to change the audio during conversion either.
Every search turns up enthusiastic "instructions" that NEVER produce the "no changes" results I'm looking for. The instructions for using VLC to do this come closest to working, but the file sizes change drastically. Original file size could be 5 GB but the converted file is ALWAYS much smaller... like 2 GB or 2.5 GB. I know enough about file sizes, compression, bits, dynamic range, black and white levels (for HD and UHD) to know I can't get the same quality from a 5 GB MKV into a 2.5 GB MP4. I know this process can be done in 5 or so seconds per file, but every set of steps I find with searches produces files that are much smaller or sometimes even much larger than the originals so the conversion is NOT the "no changes" conversion I want. My understanding is that the MKV file only needs some minor tweaking to convert it to MP4 but every option for doing "simple" conversions seems to be incapable of doing the "no changes" sort of conversion. I don't want 24p video converted to 30p or 60p, I don't want video resolution up or down converted, and I don't want the audio format changed. Surely there has to be a simple way to do that. I know it takes a LITTLE more than just changing the file extension to MP4, but not much more than that!
