1 - 20 of 56 Posts
How much of a difference do they make? How you done any testing yet?
I haven't done any measurements, but music definitely sounds better! Imaging seems to pull slightly to the left...I have a bare wall on the right (opposite the sofa) that needs a panel. I'm still working on panels (for that spot and behind the L-C-R speakers). Haven't had time to watch any movies yet.
Did you document the build by any chance? I am pretty curious to see how you built these as they look great.
Imaging might be pulling slightly left because of non-symmetry within the room. It seems that the couch on the left side of your set up could be acting as an absorber and cause this off-set imaging.
My thoughts exactly on the imaging....which is why I want a nice panel on the wall opposite the couch.
I did snap a few photos during the build of these. I'll post them as soon as I have time to get them edited and uploaded.
The traps were designed around my limited woodworking skills. It's basically a stack of 703 wedges with a cloth covered "grill". I started with a triangular wood base and stacked wedges half way up the wall:
At the halfway point a center support was cut from 2 X 2's. The sides were cut a half inch longer than the fiberglass wedges, and cut at a 45 degree angle to match the face of the wedges:
The stack was continued to the ceiling where I attached another set of 2 X 2's with 45-degree face cuts. Industrial stength velcro was attached to the faces of the 2 X 2's to attach the "grills":
The grills were made from 8-foot fir strips with cross braces top, bottom, and center:
Braced behind with t-braces and L-braces:
Test fit:
The "grills" were sprayed flat black and then covered with speaker cloth from Joanne's Fabrics (not too expensive with a 50% off coupon). The velcro was stapled to the back of the grills and they were placed against the 2 X 2's in the corner that had been faced with velcro. That industrial strength stuff is quite strong!
That looks very different than expected - I was expecting a stand alone unit that could be pulled away from the wall. Nice and sneaky build, I like it.
Is there any reason you did not use OC705 rather than using OC703?
Thanks for the pics.
I bought two cases of the 703 a while back. I think I was planning on using one case to build two four foot corner traps and use the other case for some 2" panels. Somewhere along the line I decided to make the traps floor to ceiling.
Very nice, now you just need a black curtain across the rest of that wall to even out the look.
Thanks. Actually I lke the contrast of the black corners. The paint on that wall is much darker in person (the camera flash makes it look several shades lighter than it is).
Nicely done. Very clean looking.
Bryan
Discussion Starter · #17 ·
The wedges look very cleanly cut..What did you use to cut them with.?.
I assume that the're each 2" thick..
Yes they are 2 inches thick. I cut them with an electric knife (like you use at Thanksgiving to carve a turkey!). Someone out there has a video showing how he cut fiberglass panels with one of these so I went to Walmart and picked one up for $9.95. It works great and was well worth the ten bucks.
Thanks for the link...It's a very good explanation on how to make corner chunks..
I wouldn't have believed the an electric carving knife would cut it so cleanly..
Chas,
I just saw this thread and want to echo the other comments. Very nicely done, looks great and I really like your method of construction. I definitely learned something new.
Thanks for posting the pictures.
Bob
1 - 20 of 56 Posts
