1 - 2 of 2 Posts
I have a decent amount of Ruxol remaining from my basement renovation and wanted to use it for bass traps. My room does have noticeable nulls so I figure adding traps can't hurt? The only space I have available is in the rear corners next to the back row seating. I have a space that is 9"wide x 16" long and 6ft high. My original thought was to build scalene triangle shaped wedges, but would a rectangular shape give me more absorption (in the real world)? The triangle shape would give people setting in the back row a little more elbow room but performance is more important and it isn't often we have people in the back row anyway.
there are alot of wedge shaped traps out there.if your stuffing corners they get thick in the center.the company i purchased some traps from they make wedges.gik acoustics calls em tri-traps.wedges in your rear corners would make a difference.id fill those corners floor to ceiling if possible.make a rectangle shaped one on the middle area of that wall. would be even a bit more help.
1 - 2 of 2 Posts
