Did you Calibrate SPL and Set Target Level at 75dB?
Can you show me the Impulse response graph.
Can you show me your REW Settings/Soundcard tab.
Did you Calibrate SPL and Set Target Level at 75dB?I calibrated my sound card then did a measurement while still in loopback and it comes out perfectly flat but it always has a large (like +10db) offset.
Can you show me the Impulse response graph.Another issue I have is when doing actual measurements software comes back saying I have something above 60db during the pre silence check.
Can you show me your REW Settings/Soundcard tab.I think I have something goofed up with my levels.
You are supposed to set it to 75db.....Yes I did calibrate SPL, it was fairly high though 96
Hopefully, you've read the REW HELP FILES......What should I target the handheld SPL Meter for (i.e. Stereo system volume) during REW SPL calibration?
Well, you still need to use your SPL meter to set the 75dBSPL level in the room with your receiver (while holding it near the ECM8000)... and then you put that SPL meter away, and then set the input level into REW from the ECM8000......Also I have recalibrate SPL when I rehook the real Mic up (comparing to a handheld SPL) and it doesn't have to be exactly 75db
Correct me if I'm wrong but...Well, you still need to use your SPL meter to set the 75dBSPL level in the room with your receiver (while holding it near the ECM8000)... and then you put that SPL meter away, and then set the input level into REW from the ECM8000......
bruek
Not at all. It can be anything you like.I don't think it has to be 75db though
Ah ok, so when measuring the SPL during SPL CAL you want 75 on the Meter in hand too so we are all on the same scale. Tha tmakes sense.Not at all. It can be anything you like.
Since we spend a lot of time evaluating and comparing responses here, it's nice to have a pseudo standard so everyone is on the same page. So we came up with a standard set of vertical and horizontal axis with a reasonable swing of 60dB that allows a +/-30dB swing around a 75dB target.
It works quite well and everyone seems game to comply.
But sure, if you like 84dB - fill your boots....
