Cream&Sugar™ Ultra
72276 Views 178 Replies 26 Participants Last post by  Philnick
10-18-13 Addendum: The Valspar paints have changed (and some not for the better) so we are now suggesting that Valspar Signature be used instead of Valspar Ultra. The tint formula is the same. All mixing is the same.
The change in physical makeup of the metallic silver paint used to make the previous Cream&Sugar™ mix means that particular mix (or series of 3 mixes actually) can no longer be recommended unless the old Craft Smart Metallic Silver is still available to you.
Introducing Cream&Sugar™ Ultra! Like the Cream&Sugar™ mix before it, Cream&Sugar™ Ultra is a binary mix (only two paints are used). Both paints are usually easily obtained locally throughout the U.S.; development is continuing in the use of a paint available from Home Depot as well which I'm sure will be glad news to our northern neighbors in Canada since there are precious few Lowe's stores there.
The base paint is Valspar Ultra Premium Interior Latex Flat Enamel Base 1 with the following tint and amount - 115-0.67 for a quart of paint.
Addendum:The Valspar Ultra Premium Flat Enamel paint has been renamed by Lowe's to Valspar Ultra Premium Super Flat Finish. The paint is the same, just a different name, so the existing tint formula will still work.
Note that the photo below is NOT the Base 1 paint, but rather the Ultra White base.
For those coming from looking at the original Cream&Sugar™ thread please note that the ratio of base paint to silver paint has changed for Cream&Sugar™ Ultra, it is now 50% base paint and 50% silver paint (a 1:1 ratio).
To make 32 fl. oz. of mix (before thinning for final application) buy the following items:
1 quart Valspar Ultra Premium Super Flat Finish Base 1 tinted 115-0.67 (available at Lowe's)
16 fl. oz. Liquitex BASICS 'Silver' acrylic paint (four 4 oz. tubes or two 8 oz. tubs). This paint is available at most arts and crafts stores such as Michael's and A.C. Moore. It is also available at great discount from many stores on the internet.
Now the tricky part. Since the mix is 1:1 that means only 16 oz. of the quart of Valspar paint is used, to which is mixed the 16 oz. of LBS (Liquitex BASICS 'Silver'). While you could just add 32 oz. of LBS to the quart of Valspar paint, LBS is a fairly expensive paint and it would make way more mix than most people would need. So yeah, the tricky part is measuring 16 fl. oz. out of a quart of paint. :D
Because the LBS is so thick the mix DOES NEED TO BE THINNED, even to roll. For those rolling I would recommend adding at least 25% distilled water; those spraying would have to dilute even more depending on their sprayer. Add the water and mix thoroughly, this mix is slow to accept the added water. Mixing thoroughly is VERY important!
For what I will assume would be the standard C&S™ Ultra mix of 16 oz. Valspar and 16 oz. LBS that means an additional 8 oz. of water should be added to thin for rolling. It would be a good idea to also use some of this water to wash out your containers of LBS to get all the paint out. If you are using the 8 oz. tubs of LBS simply pour the water into the tub, cover and shake. If using 4 oz. tubes of LBS I found it works best to inject the water into the almost empty tube with some kind of syringe, close the lid and shake WELL.
Cream&Sugar™ Ultra is a N9.2 screen mix which is brighter than the N9 of the previous Cream&Sugar™ mix. This means C&S™ Ultra will not perform quite as well in ambient light as C&S™, but it also means the mix will be even brighter than C&S™ in a home theater that has controlled lighting and dark walls.
Data and photos to follow.
121 - 140 of 179 Posts
Hi Neil. Sorry for missing your questions (and many others as well) on the forum, but family health issues have taken a turn for the worse so the time I can put into this forum has decreased dramatically and this may not change for some time. My sincerest apologies to all. I will still do what I can though. ;)
I have used ArgyllCMS for spot readings and the Spotread -i setting will let you choose D65 for CIE readings. I don't believe the i1Pro2 lamp is natively D50 (but I could be wrong); I know the I1Pro's lamp that I use isn't, it's listed simply as "tungsten".
My custom spreadsheet basically uses the Lindbloom spreadsheet to do all math calculations from the raw spectral data, including generation of RGB data. I did not personally write all of my spreadsheet so I hesitate to share it, sorry. There is a free program called OpenRGB that I use a lot as well that gives readings in a number of color spaces including RGB.
The BOC samples I have are all about N9 and have no gloss to them at all so I would guess that their gain would be the same, or very close to, a Lambertian surface the same color. According to OpenRGB that gain would be ~0.76 (the Y value of the XYZ reading).
The purpose of adding aluminum or mica flakes to a paint or paint mix is to increase reflection over what gloss can do alone. Aluminum is better for projection screens because it is an opaque solid so light cannot be refracted by it. Mica flakes of the size used in "metallic" or "pearl" paints are transparent and there WILL be some refraction (color shifting) caused by that. That refraction can be controlled by using enough opaque paint (white or gray) to absorb most of that refraction. That is the real difference between C&S™ Ultra and the mixes promoted on AVS. The AVS mica-based mixes even make this refraction worse by using clear polyurethane to make their mixes even more translucent thus increasing the refractive properties of the mix. Our mixes (even the mica-based C&S™ Ultra) have never hot spotted to my recollection or shown other negative refraction attributes. Mech is the one who can do gain testing and this hasn't been done with the new Black Widow Ultra™ mixes at all, and as I recall only the on-axis gain of C&S™ Ultra was done (about 1.0).
The one thing you can be sure of (and please test this to your hearts content) is that the AVS mixes (if you decide to test them) WILL have a noticeable viewing cone. They like to "prove" this isn't so by taking screen photos, but they many times forget to mention that they use the AUTO settings on their camera which means that those side shots that show an equal brilliance ARE compensating for the dimmer image. :doh:
Black Widow Ultra™ and C&S™ Ultra have increased on-axis gains compared to regular paints the same color. This difference will diminish as the gloss level of the regular paint increases. Also, while definitely noticeable, the added gain of our reflectively enhanced mixes doesn't make a night and day difference as we wanted to keep any viewing cone minimal. If there is enough interest in higher gain mixes that are close to hot spotting we may go there as well, but our interests have been more toward a large viewing audience that demands a minimal viewing cone.
I am excited to finish my DIY screen!! I am using a BOC from Joann's and spraying it with C&S Ultra. I have made a frame and mounted and stretched the BOC to a 102" 16:9 fixed screen. It is now time to paint it.
One thing I noticed after I mixed the paints (as I always do :duh:) is that the base paint in the Valspar Signature paint that I bought was "Base A" (Ultra White) on a Mate finish. I came back here to try to verify this was the correct base with the new Signature series, but I couldn't find anything that said "Base A / Ultra White / Mate", so I was a little concerned. I tested the mixture on a surface and it did look pretty flat to me. Also the tint of the paint (base+115-.67) did look white with a slight pinkish hue as mentioned earlier in the thread.
If anyone else tries this C&S Ultra, trust me, you do want to follow the instructions and water down the Liquitex BASICS Silver before mixing it with the Valspar paint (especially if it is cold, it is winter here in Iowa), unless you like stirring paint for 20 mins straight and would like to find out what muscles on your hand are the ones you don't use very often :).
One noob question I have: What gain would this mix give you if any?
I intend to use this 102" C&S Ultra screen with a PT-8000U, in a light controlled environment (basement that I'm finishing with one room being dedicated to HT) but at times I would like to have some ambient light. Should I stick with just the C&S Ultra, or add a little N6 to it?
I will have to check on this to be sure, but I believe you have the correct base for C&S™ Ultra.
Yep! :T The stirring required should be done with a "squirrel cage" mixing attachment for a hand drill. Use low speeds.
The on-axis gain for C&S™ Ultra has been measured at 1.0. This might not sound like a whole lot of gain, but know that a regular flat N9 paint would have a gain of about 0.8.
This is where things get really subjective. Keep in mind that the more N6 paint you add to C&S™ Ultra (producing an ersatz Elekta mix) the lower the gain will be, but the more the screen will absorb ambient light and give better black levels and richer colors.
I will have to check on this to be sure, but I believe you have the correct base for C&S™ Ultra. Yep! :T The stirring required should be done with a "squirrel cage" mixing attachment for a hand drill. Use low speeds. The on-axis gain for C&S™ Ultra has been measured at 1.0. This might not sound like a whole lot of gain, but know that a regular flat N9 paint would have a gain of about 0.8. This is where things get really subjective. Keep in mind that the more N6 paint you add to C&S™ Ultra (producing an ersatz Elekta mix) the lower the gain will be, but the more the screen will absorb ambient light and give better black levels and richer colors.
Thanks for the reply!
I will give it a try without the N6, and if I decide it needs to be darker, then I'll add N6 to it.
I checked and you have the correct base. :T
Great!! Thank you for following up, I really appreciate it. This is one of the reasons why Home Theater Shack blows everything else out of the water!!!
Hi! Long time, no post, but I'm back.
I've been using a screen made with the original C&S formula since July 2008, but my sweetie recently tripped and fell against it while holding a black barbell, making a gouge and a few black paint streaks. I spackled the gouge and went looking for my old mix, which I'd used to patch a few spots over the years.
My original leftover mix was all dried out (and full of rust flecks from the paint can) - no real surprise after nearly six years - but I still have half a gallon of the Sherwin Williams Luminous White base in a plastic bucket covered with saran wrap held in place with a large rubber band.
A temporary patch I did with the pure SW LW is, of course, brighter - though that's only visible when in a bright area with no detail - which is also when the eye will generally be drawn away from the patch by detail somewhere else. It's quite obvious when the lights are on, however.
I do want to repaint the whole screen soon, even if no one else notices the patch during screenings.
If I mix leftover Sherwin Williams Luminous White with the new Liquitex BASICS Silver paint, would that make a decent C&S?
Finally, will that make enough to cover - with a roller - a screen area 9 1/2 feet wide by 5 1/3 feet high? One coat should be enough, since it's going over an existing C&S screen, though I might "prime" the patch - which is an irregular area less than 6 inches by 9 inches - by giving it a first coat of the mix to make for a more uniform final coat. I'm figuring on needing to cover about 51 square feet.
From this post, which calls for one ounce per square foot for all coats combined, it sounds like I would need a bit more than 51 ounces to be safe. Is that before or after adding the distilled water?
If I don't use the leftover Sherwin Williams I'm going to use a "not quite half a gallon" 30 oz can of the Valspar Signature (which is the same price as a quart!), with 30 oz of the Liquitex. How should the tint numbers for the Valspar be changed?
If the 0.67 is the amount, my calculation is that it should be 115-1.25625 for 30 oz of the Valspar. Am I right?
I think it would work, but we haven't tested SW 'Luminous White' base for making C&S™ Ultra.
Yes, that 1 fl. oz. per square foot of screen includes the water. Also, this is just what I consider a truly safe amount of paint; many have gotten by using half that amount. Do you feel lucky? :R
I think priming the patch with a real primer would be the best bet since primer is meant to seal the substrate so the top-coat paint won't soak in. If the screen has already been coated with original C&S™, and no filler has been used to patch it, then you could probably get by without the use of primer.
You mean you would be using 30 fl. oz. of base and adding 30 fl. oz. of LBS? That would make 60 fl. oz. to which at least 25% distilled water should be added to thin it. That would be 15 fl. oz. which would create a screen mix of 75 fl. oz..
The 0.67 quantity of 115 tint is for 32 fl. oz. of base paint, dropping the amount to 30 fl. oz. would bring down the tint needed to 0.628, but honestly I wouldn't worry about that small a difference.
Has anyone found a source for the Liquitex BASICS Silver paint in jars rather than tubes?
I've been searching for weeks, since I'd much rather use the "pour in some of the distilled water, put the cap on the jar, and swish it around" method to get all of the silver paint, instead of using a syringe to inject water into each of eight four ounce tubes.
So far, I haven't found anyplace that has the 8 ounce jars.
Has anyone here found a source isn't "back ordered"?
Sorry for the lateness of this response, but life isn't allowing me as much time on the forum nowadays.
Amazon has the Liquitex BASICS Silver in 8 oz. tubs (actually sold by Create Art).
http://www.amazon.com/Liquitex-Basi...&sr=1-3&keywords=liquitex+basics+silver+paint
PEARL also has it for less money (unless they charge more for shipping).
http://www.pearlpaint.com/shop-Liquitex-Basics-8oz_8825_8824.html
I also see that some places where it is out of stock will have some in about a week.
Hello,
I've taken two trips to Lowe's and haven't figured the paint thing out yet. On my most recent trip I gave the lady the tint numbers 115 0.67 along with that paint and she told me I had the wrong numbers and this wasn't possible. She said there wasn't a 115 tint in the Valspar Signature paint. She seemed overly confused when I originally said I had a tint number not a name or color match so I'm not sure if she didn't know what was going on or if I said something wrong or if this has changed.
Thanks in advance for the help. I just don't want to mess this up.
I ended up ordering the 4 oz tubes of the silver, when Jerry's Artarama, which had consistently had the 8 oz jars marked as coming in "in a week" - for a month, always pushing the date off into the future - called Liquitex for me and reported back that it was told that the 8 oz jars of silver had been discontinued.
I'll have my order of silver this week. Rather than injecting distilled water with a syringe, would it be feasible to simply cut the empty tubes in half and swish water around in each half?
Coming from the original Cream&Sugar based on flat latex Sherwin Williams Luminous White, I'm also a little concerned about the new formulation using a white paint that isn't flat but somewhat reflective. Is there any risk of hot-spotting with a Panasonic PT-AE2000U LCD projector only 13-14 feet away, sitting 10 feet from the screen in line with the projector? My walls and ceiling are flat white, so bounce light off the screen could easily come back, if this mix throws off more of it.
What color does the 115 tint make the Valspar, compared to the Sherwin Williams? I'm wondering if I'd be better off using the Liquitex with the original flat white base + the distilled water.
PS If I do use the 30 oz can of the Valspar, would the reduced quantity mean I needn't bother rinsing out the tubes of silver with the distilled water to get the last little bit?
Well that's a bummer.
Use whatever technique you want to to get as much of the paint out of the tubes as possible. The BASICS paints, while not heavy body acrylics, are still quite thick.
I think C&S™ Ultra would work fine in this situation, but if you have any reservations about having too much added gain from the slight gloss of the Valspar Signature paint you could use the Valspar Ultra in a flat finish.
115 is (or was, I'll have to check to be sure; will do so today) the Lowe's tint code for their Magenta tint. So little tint is added to the recommended base that it is hard to tell the tinted paint isn't just white; so you could use your SW white paint if you want to. The resulting mix would not be as color neutral, but it would still be more neutral than commercial white screens. ;)
The BASICS paint is so thick I would still try to get as much of it out as possible, but don't worry about getting every drop. :D
Hi! Welcome to HTS!:wave:
It sounds to me like you got a salesperson that didn't know the Lowe's paint system well at all. 115 is the Lowe's tint number for their Magenta tint. I'll be going to Lowe's today so I will check to make sure they haven't changed their tint system.
I totally understand, and thank YOU for the post! If Lowe's has changed their tinting system we definitely need to know!
I'm mainly concerned about hot-spotting, since I sit just a few feet in front of and below the projector. (One of my first experimental screens, before I came upon Cream&Sugar, was a 4 x 8 sheet of drymount board, which had a shiny surface and very severe hotspotting.)
If I go with the Valspar Ultra in a flat finish are any changes needed to the recipe?
Nope.
I just got back from Lowe's and it seems that they have discontinued the finish they first called "Flat Enamel" and then renamed "Super Flat". Just get the Valspar Ultra in Flat finish. I also noted that they seem to be changing the Valspar Signature "Matte finish" to "Flat finish". :unbelievable:
In reference to vette_311's problem getting his Lowe's store to tint Valspar Signature with the 115 tint - I was just at Lowe's and asked about this. The answer is that while there are tint codes that can ONLY be used to color the Signature line of paint, the Signature paints CAN be tinted using the older Universal tints such as 115. So the problem is that vette got a salesperson in the Lowe's paint department that didn't know what they were doing.
Thanks very much for the welcome and the help. I've been looking around here for quite some time and am pretty excited to have a place where I can paint a screen now. I am going to give it another try at a different Lowe's tomorrow.
Hi all,
Does anybody know how to translate the color code ( 115-0.67) to international color codes? I am thinking NCS or maybe HEX? I do not know much about these things, but I am trying to make the right color for C&S Ultra and the 115-0.67 is puzzling me a bit....
Thanks.
//Jesper
Hi all,
Thanks.
//Jesper
115-0.67?:huh:
If you tell us your set up (projector brand and model, distance from the screen, screen size, hours on the lamp), we can help you picking the right shade of gray for your screen.
