1 - 3 of 3 Posts
G
I have a Creative Soundblaster Live! 24-Bit External card installed on a Dell XPS 410 with 2GB RAM and Windows XP to replace integrated sound that came with the system, a sound problem developed recently that I never noticed before, there is a popping sound in the right channel which isnt loud but noticeable when no other audio is playing, the sound is a fast popping sound like a idling engine, Ive tried updating the Nvidia video drivers, uninstalling software that may have caused conflicts, looking in the bios, I also tried uninstalling the Creative drivers and before installing the drivers again when the system booted and detected the new hardware I could hear the popping noise without any drivers loaded yet, nothing has helped this problem, does anyone have any suggestions of what is causing the noise? Thanks for any help
Hi!
I bought the same sound card. There is a problem with the driver provided by creative.
I tried on XP, Vista 32 and windows server 2008 with my hp laptop. Unfortunately you have to install the driver because cannot recognize the device self.
Symptoms: after installing the driver I observed that when scrolling with the mouse, or displaying a window causes a scratching noise .
Windows default drivers in vista and server 2008 32-bit(same kernel) are able to handle a device, but the sound card control programs work only using a creative driver :( !
So I bought a a sound card, which cannot be control, and payed a much money for that.
Currently I don't know about modded drivers or about other drivers.
If you got one, please inform me!
Bets regards
Lizard
1 - 3 of 3 Posts
