Just now got myself a creative X-Fi sound card. My connection at present is as follows.
1. X-Fi optical output --> Yamaha RX-661's optical IN.
2. A two channel set up with Definitive Technology Pro Cinema Monitors and a Jamo Sub crossed at 120Hz.
3. For the mic I am using the mic that came with Yamaha's YPAO auto callibration. (Need to get a good one with line level output)
I just ran a measurement with mic connected to line in and there was no response. Then I connected to the mic input (I know that this is not correct and I need to get a new mic).
Is this set up any good ? Please advice.
My sub specs says 36-150 Hz as the freq handling ability of the sub and the response also shows a similar graph. Does it mean everything is good or it could be a calibration error ? Please advice ?
