1 - 4 of 4 Posts
I read that it has a 12 dB/Octave roll off below 20Hz.
I e-mailed Crown, and they sent me the message below. I asked them if I can use a mini-DSP to counter that roll off.
My concern is: I want my sub to play 16Hz.. If I use Mini-DSP's steepest slope at, for example, 14Hz - should I be safe?
Frequency wise it will only go down so far, getting below 10HZ you could start getting in the area of trigger the DC/LF circuit which would trigger the amp to go into protect.
I honestly would look into a different amplifier for sub duties. Behringer Inuke series comes to mind for a cheap performer and it already has dsp built in so no need for a mini dsp.
1 - 4 of 4 Posts
