In terms of providing the necessary power to drive them safely, yes. Any of the Crown XLS series amps will do the job. Just remember that you're getting modern D-class circuitry, and if you're using xxx0/xxx2 series models you're also getting switch-mode power supplies (and variable HP/LP filters/Xovers depending on mode). There's a detailed and seemingly endless debate about how audible the differences are between various architectures... your mileage may vary. But the bottom line is that from a purely technical standpoint it will work and you won't do any harm.
The good news is that if you buy one new, you've got 30 days to return it if you're not happy.
