crown xls1000
789 Views 1 Reply 2 Participants Last post by  Wayne A. Pflughaupt
How do you all think about useing one to power 2 4ohm drivers off of each channel? I am currantly using 200 w plate amps for each and would like to run them with one amp. And gain some power.
1 - 2 of 2 Posts
Looks like you can run all four speakers on the Crown, as it is rated for 2-ohm operation. However, if you’re currently running four 200 watt plate amps, you aren’t going to gain much in the way of power with the Crown. It’s rated for 550 watts per channel @ 2 ohms, but that will be divided between the two speakers each channel will be driving. So, you’ll end up with 225 watts to each speaker.
1 - 2 of 2 Posts
