Status
Not open for further replies.
301 - 305 of 305 Posts
What do you mean by go out? Does the red tube cut off completely or go out of convergence?
Thanks for getting back to me. The Red tube will go out completly and will come on if you turn the red adjustment in the back of the set wich will cause too much red in the picture or you can unplug the set from the the outlet and let it set for a few hours and it will work like normal.
Red adjustment? Do you mean the screen voltage adjustment for the red tube on the High Voltage Block?
Is there a red cable coming out of it?
Plain ole user
Discussion Starter #303
This discussion should not be in this thread. Please start a new thread in the manufacturer's forum and I will move the posts there.
Plain ole user
Discussion Starter #305
Anyone coming to this thread should be sure to read the first ten posts very carefully. If you are not confident that you understand all of the possible problems that you may encounter or are not confident in your troubleshooting and repair skills, I strongly suggest you consult a professional. You can find many of the best techs at the link in my signature.
Status
