Status
Not open for further replies.
21 - 40 of 305 Posts
Thanks for the input. I will continue to use the "wall wart" it is easier that way too. The TV has been working flawlessly. I'm as happy as a bug in warm poop.
T
Guest
OK. took the board out and seem to have a blown resistor. can i run the tv for a short and not cook the new ic's till i get a new resistor, or not good idea?
Plain ole user
Discussion Starter #23
Never run any product with a known bad part, especially a convergence circuit with even one bad resistor. They are there for a reason and it is very possible to cause more problems.
J
Guest
Thanks to all the great info I was able to swap out the original convergence chips for aPT53W53G with 2 new -150's and everything works like new. All of your advice and comments were spot on.
T
Guest
OK folks, here's the scoop. I changed out the convergence chips on my 43UWX10B from STK392-110's to the new Hitachi STK394-160's. I also ended up swapping out the RK50 resistor, a 2.2ohm 1W, metal oxide resistor. The first run was a tough one. The screen was completely FUBAR'd and I thought all hope was lost. The blue was so far out I thought it would never come back. On top of things, my son and I began to smell something burning, and upon inspection behind the TV noticed the RK50 was glowing cherry red. I immediately unplugged the TV and was gonna give up. I had an extinguisher nearby, and said "screw it, i'm going for it". 20 minutes later in the DCAM and it actually looked really good. I was definately impressed with the picture, it seemed to be just fine. I unplugged the TV and metered the resistor, it was now cool and metered to 3ohms, outside the 5% tolerance of the 2.2. I attributed the bad resistor to the new convergence chips and the TV being so far out of whack. Luckily, I bought two, replaced it again, now with no glowing sensation, ran DCAM again, ran magic focus a couple times, and all seems to be extremely well. I am very happy with the picture, and the high-def kicks [email protected]#! I want to thank all of you again for your help, and I hope I don't need it, but if I do, I'll know where to look. :whew:
A
Guest
lcaillo, you rock!
Thanks for your time and sharing your knowledge. As a newbie I learned 2 tings. First, I'm probably going to pay someone with experience to do the repair (don't want to burn down the house). Second, the tech I had originally called for a quote is a bum! He quoted $600 and wasn't a fraction the professional you are. Thanks for your help!
Plain ole user
Discussion Starter #27
You are welcome, but please post some details about the repair when you get it done. I would be curious what it ends up costing and where you are located. While $600 for a convergence repair is twice or more what I charge, some parts of NY have a cost of doing business that is proportionally that high. If you do get it done significantly cheaper by a legitimate business, I would be very curious to know the names of the shops so that we can quiz them on how they price repairs. Consumers need to understand how servicers come to charge what they do. Some are a rip-off, but many just are trying to make a living.
J
Guest
Hello, My Pioneer sd-533hd5 broke agin. I had the convergence chips repaired last year for $600. Now when I try to turn on TV it turns right off. I checked all fuses and they are fine. There is a red led light on , on one of the boards. Is there a way I can fix this myself, is it related to convergence repair? To pay another $600 for a 6 yr old tv seems rediculous. At that point I could have bought another brand new one. Any help would be very appreciated,
Thanks, Joe
Plain ole user
Discussion Starter #29
I don't do a lot of Pioneer anymore, but over the years I have learned that most pioneer sets need to have hundreds of solder connections re-done, as they never seemed to master the process of getting parts soldered in a manner that would last very many years. There are lots of possibilities and one would need some troubleshooting experience and service literature to do any real evaluation of the set, but I rarely service a Pioneer that does not start with resoldering lots of connections.
B
Guest
Hi, great info!! I should be able to put it to good use. But first, I must be sure the problem I see is due to a convergence failure. It seems the only issue is with the blue. There are arcing blue lines through the bottom 1/3 of the picture and the upper corners are blue. I attached a couple pictures to illistrate. Please take a look and advise.
Thanks!
Either a pincushion amp or the convergence board is defective. Probably will require a service call. Dennis
Plain ole user
Discussion Starter #33
All pincushion correction in these sets is done via the convergence generator and convergence output amps. One channel (blue vertical) of one of the ICs is likely bad, with perhaps a resistor or two. Read the posts ar the top of the thread for more info.
B
Guest
Thanks for your reply! Another question, if I order the Hitachi kit, will the resistor values be the same as what is in the board?....this is a Panasonic model PT51HX41E, chassis #AP820.....which kit should I order?
Thanks
Plain ole user
Discussion Starter #35
No, they will not be the same. Each set has a unique circuit even if the chips are the same. If you just want the chips get the one that you can find cheapest.
M
Guest
While the 12 volt supply might be able to handle the extra load, for safety reasons I would recommend not trying it. You also may get some noise feeding back into the video or audio circuits from the fan. Just keep using the wall wart.
Just wanted to say thanks lcaillo, for all your time to put this thread together , I was very nearly caught up in the extorsion that my local repair guy (Gold Coast, Australia) was about to inflict on me.
He would not even look at the set unless I let him pick it up, and that was $110 ,whilst the repair would start at $300 on top of that. He had no phone credit to return my calls , and I dont think I would have put my dog in his van , let alone my 134cm.:wits-end:
So feeling helpless, and after sneakily finding out what and where the convergence board was, I came up with the STK392-120 chip number , entered it in the google search , and well here we are.
Cut a long story short, In australia I cant buy these IC's any cheaper than $130 each+ freight, so after buying them online from "Electronic Repair Kits" in Canada (Got 2 Pairs ,1 Pair For later) They arrived in 4 days and cost $5 air freight, which was cheaper than the freight in my own country. Also the IC's cost me $15 each as opposed to $130 each over here.:T
So after following clear instuctions, that I found on the net.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
And then proudly turning the TV on, in front of the "astonished" Wife and Kids , Im glad to say if I wasent a legend in their eyes before ,I certainly am Now ! (thanks to you):hail:
So one question before I wind it up?
I have noticed the 2 big heat sinks on my IC board, Getting very hot.
( by the way my TV is an LG PT53A83T ), ,
So much so that I can only hold my hand on them for a matter of seconds before getting to hot to touch.
This cant be good , and after reading the thread and any other thread I can find on this , Was wondering is this normal ?
I noticed one Gentleman in this thread putting a PC chip fan , on his heatsinks which seems like a great idea , however wouldn't he have to keep turning the tranformer on and off with the TV, Or can you get them that only turn on with the sencing of heat ??????
Any advise is appreciated, and once again thankyou for your great thread.
Kind Regards Marty. :bigsmile:
Plain ole user
Discussion Starter #37
These ICs run hot, but some sets hotter than others. Excessive dc ofset or excessive correction at the edges of the range of the chips can make them run hotter. I don't have a problem with fans, as long as they are mounted externally and do not use any of the internal power supplies in the set. I would start by verifying the setup is consistent with that in the service literature for your set and that there is no more than a couple hundred millivolts of dc on the inputs to each channel of the output ICs.
M
Guest
HHmmmmm, thanks lcaillo, soldering in the New IC's may have elevated me to Legend status with the family, but Im out of my depth well and truely now.
Any Ideas on how I would start to verifying what you speak of.
:dontknow::dontknow:
Regards Marty
B
Guest
Icaillo,
Thanks, I'll order individual STKs. Where is a good source to order a schematic? I'd like to know what resistor locations to check and have an idea what resistance to expect. Is it a good idea to relace the caps as well?
Thanks again!
Brad
Plain ole user
Discussion Starter #40
Regards Marty
I am happy to provide general advice or obvious symptom repair info, but cannot provide step by step troubleshooting on specific sets, nor start a tutorial on service torubleshooting. If the info that I have provided is not sufficient, I strongly suggest that you get a professional involved.
Status
