Okay, i've been lurking for long enough.
A few months ago i was looking for a replacement sub for my Maw-15. i happened to have wired it to a bridged RMX2450 and ran it to clipping when i left the room... Anyways, after frying a VC i figured why not build a real sub that can take the abuse i was giving the other one.
I met Mark (Mwmkravchenko) while i was working for bell, and we got to talking about what kinda sub would work best for my room. Roughly 23'x20' Basement with concrete walls. No size constraints, and a beefy 15" or 18" woofer to compliment a low tuned box.
We came up with this... (i should say he did.)
14 cubes, tuned to 16 hz lightly stuffed with a CSS SDX 15.
The box would have a down firing subwoofer and a slot port to the far side of the box. As i mentioned above, its got an RMX 2450 bridged to it wired for 4 ohms.
http://smg.photobucket.com/albums/v144/Binary110/Sub Build/
This sub is impressive. Thanks for Mark for the time and effort to build this beast. Amazing quality in the diver. Extension down to 16 hz to 123~ db factoring in room gain of 6 db. Oh! and corner loaded to boot!
