1 - 20 of 36 Posts
Just waiting to get the final measurements for port length and tuning, but got started today anyways:
Here's the 46" piece of 16" sonotube as well as a 31" length of 6" PVC for the port:
Easy to cut this stuff. Just measure it, mask off the one side as a guide, then use a jig or skil to cut it. Like butter!
May not look neat, but its a perfectly straight cut! :)
Well, after some deliberation with Mike P., it seems I needed a 38.5" port. So my 6" PVC was useless. As luck would have it, a friend of mine was throwing out a 45" piece of SUPER THICK 6" PVC!! Voila, new port, no cost. My favorite kind of spare part.......FREE!
Also lucky is this same friend has a sliding chop-saw. My little 8 1/4" mitre saw would have been useless with this PVC. Two quick swipes and 39" port was done!
Start cutting the circles this week.....
Well, thanks to Bob at CSS, my Trio 12 showed up today. Packaged professionally, as always. What a beauty!
Endcaps, sonotube, and port are cut. All that's left is the sanding, painting, and assembling! Really excited for this build. I am even flirting with the idea of WHITE endcaps!
Discussion Starter · #14 ·
Here's the endcaps cut and glued. Not sanded yet. That's today hopefully, if I get my butt in gear. Got a couple dings on the top cap edge....may have to shave it down with a router or do some heavy sanding. Also got some grill covers for all the ports on my subs. Been meaning to do that for a while now....
Chickened out on the white endcaps, LOL. Bought black instead.
This should be FINISHED this week.
Discussion Starter · #15 ·
Finished this last week...never got around to uploading the pics.
Done some testing.....I don't know what to make of the results, or how its even possible. I need to do some further sound tests to make sure what I am hearing is right. I will update soon:
The endcaps, unsanded, and unpainted:
Bottom (driver) endcap sanded and painted with the driver press-fit into place:
Painted the end of the port tube so it blends in with the top endcap:
Top (port) endcap sanded and painted:
Driver in place:
Port in place, super-secured, air leaks all sealed up!:
Bottom endcap attached to sonotube!
All put together!
Covered!
Next to the MUCH larger Shiva-x 200L sonosub:
Looks good- with a quick turnaround too. I'm curious how it sounds compared to the shiva...as I didn't spring for shiva's in my 12" sealed sono's (couldn't afford three), but opted for eD's 12" driver- unfortunately never even thought of the trio 12.
Forgot to ask- what tuning did you build to? Also, just wanted to confirm you measured the inside diameter of the port and sonotube for measurements...but you shouldn't be surprised if you hear sweet, powerful bass coming from it:T
Discussion Starter · #20 ·
I tuned the enclosure to ~19hz as per Mike P's recommendation. I measured INSIDE diameter for the volume of both port and sonotube.
Cheers!
1 - 20 of 36 Posts
