1 - 3 of 3 Posts
Hi there,
Can someone advise me on what is the best way to cut out accurate holes for the FI Q18's. I can't find anything to do this. Tips and tricks would be appreciated please.
Any videos would be very helpful if possible.
cheers
Graham
Check out our recommended tools thread.
The best method I have found is using a router and a circle jig... it makes a perfect cut. Of course you can always use the jigsaw, but for me those are less accurate.
I have the Bosch router shown in that link... I remove the bottom plate, screw on the circle jig, mark my center on the board, drill a small hole for the jig pin, insert the pin at the appropriate measurement and route away.
Maybe someone will have some pics.
1 - 3 of 3 Posts
