1 - 7 of 7 Posts
Hi,
I'm looking for a USB DAC that has the ability to EQ the music as well. I have been using an iPhone 6s for music with the Focal Listen headphones, but hope using a DAC with a laptop might have a little better quality.
My price range is around 200, any ideas?
Thanks,
Nick
Discussion Starter #5
I'm looking to make the lowend a bit more punchy, but also just to play around with. Nothing to advanced.
There is usually a simple EQ built into the OS somewhere that you might try first. Beyond that, I cannot be specific because my practical experience is with more complex EQ functions than you seem to be seeking. Does anything here look suitable? https://www.boomzi.com/best-free-equalizer-software/
Discussion Starter #7
Thanks Kal,
Going to try some of those out. Looking at the ether the Big or Little Ego from Emotiva.
1 - 7 of 7 Posts
