Status
Not open for further replies.
1 - 1 of 1 Posts
This IS the ultimate home theater subwoofer under $6000. Four of these handle the low end for the entire Omnimax Theater in Chicago! In room with a Behringer EP2500 I have measured over 129db at listening position. The power is endless. This is the fastest, cleanest, loudest (BRUTAL IMPACT), and tonally accurate subwoofer I have EVER heard. I have had many subwoofers and there is simply no comparison. You cannot buy a better home theater subwoofer. Extremely efficient and realistic.
Headroom is the keyword here.
This is a LARGE subwoofer. With regards to that, this item is pickup only. You will need a big van or pickup truck to haul this beast.
Specs are found here.
http://danleysoundlabs.com/pdf/TH%2050%20Spec%20Sheet.PDF
If you are reading this ad, you have heard the hype surrounding this engineering masterpiece.
Asking $2300 including the Behriger EP2500. To but this equipment new would be over $3500!
45 x 34 x 25 are the dimensions.
Here are some reviews from an AVS forum GTG
http://72.9.159.100/avs-vb/showthread.php?t=1127851
I can email pics if requested. I am located in Central IL.
Thanks.
1 - 1 of 1 Posts
Status
