Re: Cream&Sugar - an N9 reflective screen mix.
Does Behr silver metallic have the prismatic effect? ***?
I haven't tested or used either, but mech says they do and test samples that were sent to me of mixes that use those paints show the prismatic effect.
Every water-based metallic paint I have tested, except the Craft Smart brand or those using aluminum flakes, has shown the PE.
Reminder, these panels are not cream and sugar! I'm using some of the same materials, and some different as well.
OK, cool; I misunderstood.
The panels I painted look like regular flat paint. I got a magnifying lens and then could see some sparlies, but spaced apart about 1/8" or so. Your picture looked to have many more visible in a 1/32" by 1/32" area.
Yes, the C&S mixes all show visible sparkles under bright light from about 8 inches away. The Craft Smart metallics have fairly large sparkles, much larger than the Delta, and most of the Folk Art metallics. IMO, any metallic flakes smaller than those in the Auto Air Aluminum (fine) are too small and seem, at least to me, to behave more like gloss than as very small reflective mirrors. I made a test panel (1x4 feet) of RS-MaxxMudd-LL and a full screen of Silver Fire. Both of these mixes contain a LARGE amount of Delta Pearl and Silver paint; it's most of the mix for Silver Fire. Neither of these show any sparkle until you get your eye extremely close to the surface.
What would you say the limit is for metallics? Is 50% too much?
This will depend on the metallic paints used. For example, C&S is mixed 2:1, base to silver. That is 33% silver paint and the white base is only slightly darkened! The most used Black Widow mix is 4:1; that means that this relatively dark paint only has 20% silver paint in it, but it is WAY darker than C&S!
I did try to use Delta Silver Metallic to make C&S just to see how it would look; I took the mix up to a 1:1 ratio (half Luminous White and half silver) and even though the mix was getting dark (too dark for a C&S mix) there were NO visible sparkles; I mean NONE!
When I get back to experimenting with my dark screen mix I will be using a mix that is almost 100% Craft Smart Metallic Silver; I will add either Deep Base or Valspar clear protector (flat) to cut down on this paints gloss, some colored paints to bring the color to a neutral gray, and perhaps some white paint to lighten the mix if needed.
My understanding is that when too much aluminum-based metallic paint is used the screen will start to look grainy. When too much mica-based metallic paint is used the screen will seem to "shimmer" in white and light colored parts of a scene.
