1 - 8 of 8 Posts
I have it up and going as of this afternoon. I will post pictures and more info tomorrow. But could someone point me in the right direction for boosting the amp, DB and HZ? Box has a net volume of about 3.8 cu. ft. And using (2) dayton unweighted PRs. Thanks!
Thank you Mike. I wanted to try it "dry" and see how it came out. I am pretty happy really aside from the amp rattle. I will give it a try adding some weight tomorrow when I attack the rattle issue. I appreciate the modeling. A short term goal is learning how to use WinISD and hornresp. In your opinion how far would you take the weighting? 200 grams or more?
I will stop at 200 grams and let the watts be what it is. This sub is in a musical setting and shouldnt see much in the low HZ range. I am not worried about KOing a PR.
**Wait** Or should I just leave the PRs unweighted for the sake of their life expectancy?
1 - 8 of 8 Posts
