ok are they sealed or ported?? If ported do you know the size of the port?? it will work in the 8cu. ft. box the uxl's if you can cut the hole bigger??The amp is a crown xls 2500. I actually have 2 Titanic 15's right now in 8 cf boxes tuned to 20 hz. When I run the daytons hard, about 5 db before clipping the amp I'm getting lots of distortion. I would like to get the uxl's but I won't be able to build new boxes for a few months so I'd run them in the boxes the Titanic are currently in.
If you're clipping the amp on the Titanics you most certainly will clip it on the UXL. Using the XLS2500 really will not do two UXLs justice. The XLS2500 puts out 775w a ch. or 2400w bridged. A sealed UXL will take the whole 2400w. A ported UXL will take 1200-1500w.The amp is a crown xls 2500. I actually have 2 Titanic 15's right now in 8 cf boxes tuned to 20 hz. When I run the daytons hard, about 5 db before clipping the amp I'm getting lots of distortion. I would like to get the uxl's but I won't be able to build new boxes for a few months so I'd run them in the boxes the Titanic are currently in.
I personally don't have experience with the the Titanic. That being said, everything I've read says that the UXL will most definitely have more/cleaner output. The UXL is a single voice coil 4ohm driver, so no way to configure 2ohm. I own a UXL and own/have owned XLS 1500 and 2500. BTW, nice driver and amps.Thanks, so do you think the uxl's will have cleaner output? And also do you know if the uxl's could be wired down to 2 ohms a piece? I couldn't find the voice coil configuration on their website.
