1 - 5 of 5 Posts
Hello HTS Members, :wave:
I am asking for opinions and advice on wether or not it would be a good idea to put a DBX 231 graphic eq before my active sub woofer and active speakers to help tune my room with REW?
If not; then what pro eq would you recomend for a full frequency spectrum tuning and where in the audio chain would be the right place to put it?
Thank you,
mixxpitt
Hello,
I would try it first without the DBX in the chain just using REW. After getting an idea of how it sounds, I would add the DBX to the mix and decide whether it is useful.
What are you using for a Preamp? I am just wondering if it might have Audyssey MultEQ which I think works far better than a Graphic EQ.
Cheers,
JJ
Thanks Jack,
I will read more into Audyssey MultEQ , especially the Audyssey MultEQ pro.
First time I heard of this Audyssey MultEQ. So far it sounds good but not sure what route to go for professional application for my project studio.
I saw that IK ARC Plugin incorporates Audyssey MultEQ; what would your advice be on that, or what would you recommend?
Thank you,
Thanks Jack,
Thank you,
I am a big fan of Audyssey and really believe they offer something special that goes far beyond EQ. So I would definitely check out that Plug In personally.
Cheers,
JJ
1 - 5 of 5 Posts
