I'm looking for a powered sub to replace my dead sub. I have been reading through the forums and have noticed that the face of home theater has changed since I last ventured for product. The brick and mortar stores are being phased out by the ID outfits. I'm being drowned in brands/ specs and finding more relevant models daily and am worried of missing out on a product to consider by not being familiar with all the ID brands I don't know of. My budget is in the +/- $1000 range. I have the following components:
5 - Tannoy Precision 8 (set up in L/C/R/LR/RR)
1 - Denon AVR X-2000
1 - Playstation 3 for games/DVDs/BlueRays (soon to be replaced by a Playstation 4)
1 - Direct TV HR23700 cable box
1 - SurroundCast wireless rear surround transmitter
I currently have one Tannoy TS12 sub which is about 10yrs old! It has stopped working so I want to replace it. It is a 12" downward firing sub. I do have active kids so downward firing sub is appealing just from the "protect my investment" frame of mind. I liked the fullness of that sub and it also had LFE controls onboard. My range of music is upbeat classical, EDM, old school, trance, Pink Floyd, dance, top 40, latin dance, latin rock and more but that should give you a range of sonics.
Room description:
* my room is 16.5'x21' playing long ways
* I have a tiled floor
* there are lots of windows
* one of the long walls opens to the kitchen with a long counter and a hallway on either side
* the ceiling is raked on the short side from 18' down to 8' with an opening to a room above
Usage description:
80% movies
15% gaming
5% music
Volume level:
I like loud volumes for some viewing but don't want to sacrifice quality at low volumes either.
I also need to run wireless to the sub and place in the back corner of the room. That adds to the cost of the Rythmik. I have talked to reached out to Rythmik and spoke to Brian. I reached out to HSU on their forum but had no response yet. I'm trying to make sure I get the best economical choice but not sacrifice on my listening experience. I also considered the HSU ULS15 since it comes with wireless but am being advised to stick to ported since we are so movie heavy in our experience. I have also been warned about the wireless but see that others have done it with success. Would my receiver compensate for any delays? I have asked HSU about their specs on the wireless but have not heard back yet. I don't want to lose the lower freqs for the movies. I posted in other forums so am looking for more input but don't want to delay in more of my own indecision. Any other options I may be missing on with good response? :/
Thanks!
Room description:
Usage description:
80% movies
15% gaming
5% music
Volume level:
Thanks!
