Ok, here's my dilemma. I used to own two THT's... they had more output than I could ever hope for, but they didn't like being corner loaded with the horn facing the corner... produced some rather boomy bass that I could never get over, and of course they showed their limitations when you faced the throats into the room. so I changed over to two SI 18's in 12 cu ft ported boxes (martysubs) and cleaned up the bass dramatatically. only problem is that I miss the insane OUTPUT that the THT's afforded me and I'm craving more.
My ISSUE is that I have a 12 foot wide by 22 foot long room (12 food wide section is where the screen is at and my room is open to an addition to the left (no door with a 7x6 foot opening that I KNOW is sucking out output like a sponge( and opens up into the kitchen and a hallway in the back (not as bad, small openings)
here is a picture (excuse the cruddy picture, I was lazy and just used paint
now the decisions I have is three fold. I'm thinking of adding two more marty's to add to the two I have... one in the front left (can't fit two more up front, my equipment rack and center would have no place to go) and one just to the left/behind of the seating arena where the X is.
the second option is to take out my SI 18 d2's, use them on the amp I have for nearfield subs and add 4 more sealed to go up front with a total of 6 SI 18's in the room vs 3 or 4 ported si 18's....
the LAST option is to turn my si 18's into sealed like I mentioned, use them as nearfield and add two Gjallarhorn's up front (using UXL 18's instead of the LMR Ultras) and lie them on their sides with the throats facing into the room (I figure their insane amounts of output will overcome not being corner loaded
any thoughts on the three options?
