Have you contacted Definitive Technology? That is likely the only place you might get that information. Speaker companies do not generally publish this information nor distribute it in the way that electronics manufacturers do. The only way that you usually get that kind of info on speakers is to ask the manufacturer.
Why would you need to know, anyway? Crossovers are pretty straightforward to simply observe and test.
