If the version you’re using shows the individual measurements stacked on the left side of the screen, you can individually delete the ones you no longer need.
Really, a “Delete All” function makes little sense. If you no longer need any of the measurements in the file, just delete the whole file.
I've been doing that, and they don't delete, neither singly nor the whole file! I open the file, delete, and nothing happens. They stay there and open again when I look.
So you are saying that when you click on the red “X” in the corner of the tab, or click on the file in your folder, neither one of those will delete anything?
When I click on the X in the tab, it will remove each measurement from the screen. But they will re-open if I go to the folder. There is nothing in my documents. If I delete all in the folder, it disappears from the screen, but will re-open from the list.
But I noticed if I delete tabs with the red “X” and close the file, when I re-open it they show up again. The work-around is to save the file again after making the deletions.
