1 - 7 of 7 Posts
I am undecided whether to purchase the 818 w/135 watts or the 3313 w/125watts.
Will be powering 2 RTI A9's and CSIA4 center w/sw112 sub. Tv is 55" 240 hz 3D Samsung.
Goals quality sound and video for movies and music.
I would like to keep the avr cost around $1000.00.
I appreciate you input.
Discussion Starter #2
Does anyone have any experience with Denon 3313 or the Onkyo 818.
Goals: quality sound and video for movies and music.
I would like to keep the avr cost around $1000.00 - $1500.00.
The Onkyo 818 has Audssey MultEQ XT32 and Denon3313 has Audssey MultEQ XT.
I read the XT32 is a nice upgrade, but I'm concerned about defects in Onkyo 818.
Any assistance would be appreciated.
Discussion Starter #5
I like the 135 watts per channel pluses the Audssey XT32, but read some reviews about defects.
Also interested in Denon 3313, less power 125 watts, Audssey Mult EQ. USING 1 sub Klispch SW-112.
I would personally buy separates. You can get an Emotiva UMC-200 for $499, then add a UPA-500 for $349 or go all out with a XPA-5 for $899. Should beat on either of those receivers.
If going with receivers I'd go with the Denon. The last few Onkyo's I had always had difficulty with HDMI audio dropping. (I have not owned or tested either of the models you listed)
1 - 7 of 7 Posts
