1 - 4 of 4 Posts
Is an optical or coaxial hookup better than the other?
I'm hooking up a Sony 5 disc CD/DVD player for music as well as a Sony DVD player solely for movies so that I don't have to keep switching the surround setting on my Denon. (DTS to Direct, etc.)
My Denon doesn't have an optical in for DVD or CD but rather SAT, DVR & VCR. It does have coaxial inputs for DVD & CD BUT I'd rather run an optical in rather than a coaxial.
BTW, I am running a VCR as well, yeah I know, why?
Is one better than the other? Would it really make a difference in sound quality especially on SACD's?
I know coaxial is digital but it seems to me that an optical signal would be a much better digital delivery source? :scratch:
Re: Denon 3808CI:Optical or Coaxial hookup
Neither will make any noticeable difference audibly . The coaxial cable is alot more like HDMI as far as the signal is concerned just 0's and 1's. and is alot less fragile than the optical cable.
I second the above response. I remember hearing years ago that coaxial was better, but I can't remember the reasoning. I would suggest just using whatever you have on hand. If buying new optical cable just buy entry level as quality isn't really an issue with fibreoptics
Posted via Mobile Device
Plain ole user
The downside to optical is that the cables are not as durable. Otherwise, not much difference.
1 - 4 of 4 Posts
