1 - 8 of 8 Posts
Discussion Starter · #2 ·
Denon4311
AirPlay exhaustion... Every time I switch on my 4311 a popup message for free registering to AirPlay comes. When I complete the forms it says that your details or incorrect(I swear it is correct) or someone has already registered with this ID. Someone please help:yikes:
Hello,
Welcome to HTS. I believe with the 4311, you can adjust the Speaker Crossover on each type of Speakers (Fronts/Mains, Center Channel, Surround, Surround Back, Height, and Width) Only on the Center Channel can you adjust the Crossover for 1 Speaker. All this being said, Audyssey MultEQ XT32 will set the Crossover. I do, after Audyssey, set all of my Speakers to 80hz.
Cheers,
JJ
Take readings in every listening position, if you dont have 8 positions then just take a second reading in the same spot twice it wont hurt anything.
Re: denon AVR 4311
Power supply switch wears a red halo when HDMI CONTROL is switched ON. Normal..?
Yes. Standby but pass thru enabled. You should read the instructions and Google 'batpig'.
1 - 8 of 8 Posts
