1 - 9 of 9 Posts
Video isnt that important cause audio is where this receiver is going to shine which one do you guys think is better remember the denono as better upconvert but the onkyo has great Dolby new format sound??:scratch::help:
i can get both for under 500 but the Onkyo i can get cheaper like 300ish:dumbcrazy::spend::spend::spend:
Thanks cheers mates:R
KrazyBassKevin:neener::sn:
The "height" channels that Marshall refers to are a second set of speakers above your mains. These give the sound of when objects are falling. so in essence you will need 7 speakers not 5.
1 - 9 of 9 Posts
