Hi,this is my first post so I hope someone can give me an answer.when I run auddessy on my avr it sets my main speakers and my center to 40hz and my rears to 120hz.does this seem right my bass seems to punchy.my setup is klipsch rf8211 for fronts rc6211 center rb61 rears and r-sw112 for a sub.Thanks
Even though your speakers may be able to handle going lower in room response can effect how they preform. Just to make sure when you run Audessey did you use a tripod and place the mic at ear level pointing up?
Welcome to the HTS by the way :wave:
yes I used the tripod that came with the denon avr I am just disappointed with the sound no matter what I do .this is a new setup and I just don't know what settings I should try.Thanks
Im confused, you got a tripod with the Denon? Usually you have to buy one separately.
Try this setup procedure for mic placement
