1 - 3 of 3 Posts
In REW: can DEQ2496 use the filters generated for DCX2496 (since DEQ in not listed as option on the EQ list)?
Also, the DEQ has GEQ, PEQ and FBD. If entering the correction filters manually, should it be in DEQ or FBD ?
Lastly, can the filters be exported via USB/Midi convertor set to DEQ?
Tried to search the answer, but looks like the DEQ is seldomly used?
Easiest way to check the filters is to connect the DEQ in a loopback, set up a filter and see if the shape matches the filter shape REW plots. Midi connection will not work, only works for the BFD1124P and FBQ2496.
1 - 3 of 3 Posts
