Design help
407 Views 2 Replies 3 Participants Last post by  BradPercell
hello guys i have built so.e speakers but alway bought plans. i want to build a sub with two tang band w5 and one 10" dayton reference passive radiator. also have a yung 100 watt plate amp. any help be great id even pay someone to design it thanks a bunch.
1 - 3 of 3 Posts
Just visit some sort of CNC/woodworking website, there are usually plenty of plans there and folks far more savvy when it comes to actual construction. Doubt you'll find much help here(but alas, maybe :D )
Here are a few links where you'll likely be able to find numerous cabinet designs (in no particular order). One or two of them are likely to have just what you're looking for. Nevertheless, such sites typically make interesting (and often extremely useful) reading for "builders." Best of luck finding what you're looking for.
Also, if you are able to, please post a couple of pictures of the final product. We'd love to see it.
Cabinet Plans - Madisound Speaker PDF Library
Parts Express: Speakers, Amplifiers, Audio Parts and Solutions (parts-express.com)
Meniscus Audio | Just add Solder and Sawdust
WinISD – a beginners tutorial | Midwest Audio Club
CT Sounds – CT SOUNDS
Subwoofer Enclosure Calculators, Parallel, S eries, Port Length and Volume (the12volt.com)
Speaker Box Enclosure Designer / Calculator (diyaudioandvideo.com)
Speaker Box Design | 3D Speaker Box Calculator (subbox.pro)
Subwoofer Box Calculator and Subwoofer Box Design (subbox.pro), and last but certainly not the least:
AJ Audio Subwoofer Box Enclosure Design Software - Sub Speaker Cabinet Building Program Downloads (ajdesigner.com)
Once again, best of luck finding what you're looking for.
1 - 3 of 3 Posts
