Hey everyone. I just joined the forum, looks great so far! I'm looking for a bit of guidance and help in designing a subwoofer system. It will primarily be used for live sound but doing music that needs extension down to about 25Hz. I've discovered a few designs on the internet but they either seem to be for PA use and don't have low enough extension or are designed for home theatre use and have extension lower than I need. So these are my goals and limitations:
- F3 of 25Hz
- About a $1700 budget for everything (drivers, wood, hardware, etc.)
- Total cabinet volume less than 100 cubic feet
- As loud as possible!
A few designs I've been considering...
1) 4, 18 cubic feet reflex cabinets loaded with two Alpine SWS15D4's each tuned to about 27 Hz. Theoretically this should provide about 132 dB at 30 Hz at 1 meter.
2) 4 Lilmike Microwreckers. Not too sure about how loud these will get but I estimate it to be about 134 dB at 30 Hz.
I'm open to pretty much any design type. Amps will probably be Behringer iNuke 6000's.
Thanks!
- F3 of 25Hz
Thanks!
