Hello, I currently own a SVS 20-39PC+ that I bought 8 years ago. Was going to upgrade to another SVS, but got bit by the DIY bug. This DIY design will be used for both HT and music. Satellite speakers will be crossed over at 80 Hz, but LFE (.1) channel effects will go up to 120 Hz (brick wall filter). Accordingly, the sub will need to handle up to 120 Hz, though LFE content will likely be rolled off quite substantially by then.
I was hoping for a sanity check on the following design from some of the more experienced members here.
(2) Infinity REF1262W will be in a dual opposed config, wired 4-ohm, and powered by a Bash 500 from Parts Express.
Using WinISD, I came up with a 9 ft3 (net) vented enclosure tuned to 18 Hz. The Bash 500 will have its stock HPF changed to a Fc of 19 Hz and a Q of 1.4. Corresponding FR is +1,-3 dB from 17 (F3) to 120 Hz.
With this HPF change, a max excursion of 13 mm (xmax) occurs at 14 and 25 Hz with 224 W of system input power. At 224 W, apparent amp load power peaks at 350 W and occurs at 20 Hz. Port size is 6" and first port resonance is 312 Hz. Port velocity peaks at 25 m/s at 17 Hz at this same input power.
Exact project file is attached. Thanks . . .
