1 - 5 of 5 Posts
Hi Guys,
How are you doing?
I am using a Motu 4Pre SoundCard which has 4 Input Microphone PreAmps,1 Digital Coax Input, 4 Analog outputs & 1 Digital Coax Output.
I am using all 4 Microphone Inputs for Loud Speaker Measurements, I cannot use Analog Outputs of the SoundCard back in the Analog Inputs for Reference for the measurement software as i am already using all 4 Microphone Inputs ( 4 microphones for 4 different locations in a room ) of the SoundCard for 4 Measurement Microphones.
I can only use the Digital Coax Input & Output of the SoundCard. I need to send the Digital Coax Output to the Coax Input of the SoundCard and at the same time send a Split Coax Digital Output to the AES Input of the Power Amplifiers. I am looking a COAX Splitter which can take 1 Digital Coax In and give 2 Identical Digital Coax Outputs.
Help will be appreciated, i will be grateful to you guys if you can suggest a product which can take 1 Digital Coax In and give 2 Identical Digital Coax Outputs with minimal level drop and phase.
Thanks and Regards,
Humayun
1 - 5 of 5 Posts
