1 - 8 of 8 Posts
I have been an A/V enthusiast for ~45 years. As technology has changed and improved, I find myself becoming more and more of a luddite; I find it increasingly hard to keep up with (maybe it has something to do with old age).
Having said this , I know that I need to update my system(s) to use digital download sources. At this point I know how to download/store music to my PC, but after reading all sorts of articles, instructions, etc. on the topic, I'm still befuddled about the most basic question - how to send PC downloaded/stored music to my stereo and home theater systems.
Also, I recognize that a DAC is a fundamental upgrade to improve the sound quality of digital audio files. But again I'm confused. Most DACs that I read about seem to be intended for use with headphones; but how does one get the converted signal to a separate audio system? Also, like all A/V hardware, DACs seem to be available across a very wide price range; yet I read a recent article that compared a $40 DAC to a $1000 unit, and concluded that there was no audible difference in the sound improvement.
So, I continue to be confused. I know that this isn't rocket science; and that somewhere out there is a source of the information I'm looking for - maybe "Digital Audio and DACs for Dummies"? Does anyone have any suggestions? Thanks.
I use iTunes to download all of my music, and I used iTunes Airplay option to stream my music to my Pioneer SC-1522-K AVR, which supports Airplay.
I can also download all of my music to my iPhones and iPads, and use Airplay to play my music in my HT. So, I would suggest an AVR that supports some type of Airplay feature. I also know that you can buy a Bluetooth adapter for your AVR, and use the bluetooth feature to stream to your AVR as well.
1. The simplest (and least satisfactory) way is to send line outs from the PC to a stereo input on your preamp. All you need is a music streaming program and they range in convenience and intelligence but you can start with WMP before exploring options.
2. Better is to use the USB output and insert a USB DAC between the PC and the system.
Everything else would be variations on how/where you (a) store files, (b) select and control play, (c) convert from D-to-A and (d) how you connect all.
Do you use a separate DAC to improve sound quality?
Is your audio system completely analog? Tell us what you have to work with.
No, I do not. I only use my PC / iTunes + AVR to play music via Airplay.
So, in effect, you are using a DAC separate from your PC; you are using the DAC in your AVR.
1 - 8 of 8 Posts
