1 - 3 of 3 Posts
I have dropped cable and went OTA... I am using a PC card for a tuner (not sure if I am going to keep it or go with a HDHomerun), and I get 5.1 from the OTA signal going from my PC to the 4520ci.
You can hookup the antenna directly to your TV if you don't plan on recording or you could always go with a Tivo box and be able to record. I just ordered a HDHomerun for my setup... If it works out I will be ordering one more.
I just browsed through the manual and it looks like it will work to me for analog stations... If you are looking for HDTV channels (ATSC) I didn't see any mention of them so I would say no to HDTV channels. Where you planning on HD or analog?
1 - 3 of 3 Posts
