1 - 7 of 7 Posts
Member electronbee sent me a sample of this paint to measure. Here's the data:
RGB 238 238 226
xyY 0.320 0.341 84.8
CIE Lab 93.8 -2.15 5.85
Color Temp 6067.4
Spectrum Chart
There does appear to be some sort of reflective material in the mix. I'll get a magnification up shortly.
Augh! Well... at least people know. I have also had some splotch/hatting problems with this paint which has results in bright and dark spots. You can do a light sand with 400 grit sand paper to even them out but as its paint you can only sand so much.
I'm actually looking for a DIY solution to repaint my wall.
C&S Ultra™.
I found the Black Widow thread before the C&S Ultra thread and already ordered the aluminum from BLICK! They processed and shipped the order faster than I could cancel it... so, I'll go with that paint first. There are a lot of threads on both but I have not seen one comparing them side-by-side.
At least, I will be spending a fraction of what I did on this previous paint.
Moderator Emeritus
There really is no point of comparing C&S™ Ultra (the original C&S™ can't be made anymore due to the reformulation of the metallic silver paint used) and BW™. C&S™ Ultra is only slightly darker than a true white screen and is NOT an ambient light mix, which BW™ is.
If you want to see a side-by-side comparison of the old C&S™ and BW™ using a 100 IRE white image and a color bar image see the first post of this thread. I only put up the BW™ panels to hide the wall behind them. :heehee:
When you compare a white and a gray screen side-by-side the white screen/panel will always have the brighter image and the gray screen/panel will have better contrast and richer colors unless the HT is a literal bat cave and the PJ has phenomenal black levels.
1 - 7 of 7 Posts
