1 - 2 of 2 Posts
Never heard of the Mocom. :huh: If I were to pick between a Supernova and a Black Diamond, the choice would be easy - Supernova.
Have you looked into a Da-Lite High Power at all? That may be something that would fit your situation. You could call Da-Lite and have them send you a sample of the material to see if it would work. Just tell them you want a larger sample.
I may look at that.
Problem is the pj has to be center on screen correct? Kinda difficult in my situation. Mines currently shelf mounted. 13.5 feet throw, 1.5 zoom I think, lens height just below top of screen and off entered about 70% to one side.
Yep that's a problem for the HP. Skip that.
1 - 2 of 2 Posts
