REW’s built-in SLM requires calibration, but it’s only necessary if you require graphs with accurate dB indications. If not, just run the test signal at a comfortable level and “tell” REW that it’s 75 dB.
Really? Even with the cheesy built-in iphone mic? Do you think it could come within 3db accuracy?I would not even go that far, if you have a smartphone there are plenty of free SPL meter aps that will get you good enough readings to set the correct levels on REW.
For a mic this would be the best option to use with REW
Yes C and slow will be ideal.
