I have generated the necessary measurements using REW. I am happy with the results of the exported filters as wav. file. I have measured the response after the convolver wav. file was loaded. It is much flatter and quite satisfactory.
My question is- do the filters that REW implements to change the in room response through the wav. file create a phase or time incoherence? Does this cause ringing? I am not experiencing any problems but the music doesn't seem quite as involving even though the response is much flatter.
I read somewhere else that all filters introduce phase shift whether active or passive but these filters are digital and with the wav file it is just an imprint on the music if I understand this correctly. (using the convolved wav file) If this is a phase problem how do I correct it?:dizzy:
