Does motherboard audio processing affects its USB outputs (to external DAC)?
1554 Views 3 Replies 4 Participants Last post by  jbeemon
Hello everyone,
I am currently using a MSI M3 H170 motherboard in my computer and I read that it has a lot of audio enhancements/features like noise floor canceling as well as some boosts, stereo width enhancement etc...
My question is: does all of these "audio processing effects" affect motherboard USB audio outputs to my external DAC? Or they are just meant to take effect when running audio through the jack outputs?
Does connecting the motherboard to the external DAC bypasses all of the motherboard's effects and boosts previously mentioned?
If all of these effects are being applied on the USB outputs, is there a way to deactivate them all?
Thank you for your time ❤
tp link login
sarkari job
192.168.1.128
1 - 4 of 4 Posts
It probably doesn't affect the external dac since the effects are applied on the integrated soundcard of the motherboard, but the audio signal is only processed by the dac. Anyway you can easily disable those enhancements by going into the sound section of the windows control panel and selecting the properties of the proper output device.
You can get much better sound from your external DAC with Jriver. Designed and used by Audiophiles and very affordable.
And it has a free 30 day trial. JRiver Media Center
The answer to your question is maybe. It really depends on the audio player software you use and the audio drivers the software can use. For example, the Qobuz or Foobar (or JRiver) app can use WASAPI or ASIO as output. WASAPI and ASIO bypass all of the Windows Sound mixer and are able to achieve bit perfect playback. There are other player softwares that can use these drivers. You generally have to go to the settings of the program and choose the output. Programs like Windows Media Player or Windows My Music are unable to use WASAPI or ASIO and their sound goes through the Windows mixer and thus the sound is subject to all the foibles and distortion of the Windows mixer. FWIW, I won't use Amazon HD Music because its so called app doesn't allow you to use WASAPI to bypass the Windows sound mixer. I probably didn't explain this very well but someone with more knowledge will explain it better.
1 - 4 of 4 Posts
