1 - 3 of 3 Posts
It looks correct to me.
The only minor issue I see is that the phase is inverted (indicates 180° instead of 0°). I suggest you check the box in "preferences" that inverts the phase. It should then correctly indicate 0°.
1 - 3 of 3 Posts
